Max capacity ssd
Hello to everyone,does anyone knows how much Gb is the maximum for the external ssd slot to lapbook?
I want to buy this ssd (512)
https://www.aliexpress.com/item/32812415085.html?spm=a2g0o.cart.0.0.128c3c00RCXstR&mp=1
I think the 512 SSD will work fine on your LapBook Pro.
A curiosity, when it has it, you must put it with the letters of the label inside the laptop for it to work.
Ok,thanks for that.I will continue the process.
If you need help cloning the system on the SSD or reinstalling Windows, don’t hesitate to ask
