Where should I add SSD for Herobook Air
I want to add SSD for Herobook Air. When I opened the SSD slot on the back, the SSD described as 128GB was already installed. Is this a standard 128GB SSD? So where should I add SSDs?
Hello, there is no extra slot for this model, only the original SSD can be replaced, thank you
Thank you for your reply. After that, I thought so too, and replaced the 128GB SSD with a larger capacity SSD.
When my Herobook Air boots or updates all the messages are in Chinese. Can I remove that with a clean Windows install on larger capacity SSD
