Hi, I am currently thinking about getting an SSD drive or an MicroSD card, but I don’t know which ones are compatible with the Herobook Pro?
Also, is it OK to have both the SSD Drive and Microsd card together?
Also, would I have to get someone to install the SSD drive if I chose the SSD drive?
Also, I do have the model with the ssd slot in the back and Microsd slot
ed61
2
it depends on the model that you have. the newest only has microSD card expansion, not a 2nd ssd slot in the back.
For microSD card you don’t need to install anything. It behaves as a usb drive.
If your model permits [having a removable slot at the back], you need to first check which m.2 card fits in.
There are different sizes, of which the longest and most common is 80 mm [m.2 2280].
And also you need to check how many notches it has. If 2 then only M.2 sata disks fits in. If 1 then m.2 nvme disk will fit.
M.2 disks need to be formatted, like a microSD card. However formatting needs to be done in NTFS format using the disk manager.
OK, are there any types of SSD drives and Microsd that the Chuwi herobook pro needs since I have both SSD slot and Microsd slot?
ed61
4
if you mean brands no. i also don’t have recommendations.but avoid brands sold on aliexpress for a low price.
what I normally buy are the ones that are popular on amazon and have good reviews. then I would shop around to find it.
Ed61 has explained even better that i could.
We actually dont have recommendations of SSD.
Herobook Pro Latest models are these SSD : SSD 256 GB (1 slot ,M.2 2280/2242) Sata3
But if you want to really know, just open the laptop and check the SSD that it has.Then you buy a similar one.
