SSD m. 2 2242 or 2280
which is the right type for my chuwi model CW1532?tanks
[image]
If you currently have 32GB of eMMC ROM Storage Capacity then it is most likely soldered to the motherboard and as such not replaceable with an SSD.
You have asked this in the Herobook Pro area and so this may not be 100% correct. You could try asking this question in the Chuwi Hi9 Pro area.
