I bought a 1TB 2242 M.2 SSD to fit the M.2 bay on the Herobook Pro. When I removed the panel, I was surprised to see it occupied by a 2280 M.2 - unlike on my Lapbook 12.3, which was vacant when I fitted a 512GB 2242 M.2 SSD to it.
The fixing screw hole is spaced for a 2280 M.2, so how do I secure a 2242 form SSD ? Also, what is the max capacity SSD that will function in the Herobook Pro ? The laptop doesnt seem to want to work with the1TB SSD anyway.
I’d be grateful for comments.
Thanks PP-L
