Minibook 8 N150 drivers (fingerprint not working)
Hi, I just got my Minibook 8 N150. Windows says fingerprint is not available as a login option. Device Manager doesn’t show any unknown devices though. Can you provide a driver set for this new minibook?
Serial number according to BIOS is ZMiniBIM2H250500568, bought in Indonesia (Tokopedia) today 25/6/2025.
Thx
Hi. Have you checked the user manual ?
Can you upload an image of the fingerprint reader ?
I’m asking because if you look at the image, the line with the blue exclamation mark says:
We couldn’t find a compatible fingerprint scanner.
I’m not sure what user manual you’re referring to: there was nothing in the box and the Chuwi site doesn’t even list the N150 model of the Minibook 8 yet, let alone any support documentation for it.
Anyway, this is the windows setting for fingerprint, it also shows “couldn’t find compatible fingerprint scanner”, which is what I meant when I said Windows says fingerprint is not available as a login option :
Yet device manager doesn’t show any unknown devices:
It’s the same thing I’m telling you in my post.
write to service@chuwi.com
I did write to service@chuwi.com and they first sent me a batch of drivers, that didn’t work. They then sent an installation package (basically a windows image they use themselves), that didn’t work. Finally I went to the seller and he gave me the solution:
There is a setting in windows to allow use of “external fingerprint reader”, which basically means the use of a “less secure” fingerprint reader. Switching that on and restarting the laptop did the trick, my fingerprint now works in windows as expected. Those curious, the setting is under
Settings / Accounts / Sign-in Options under Additional Settings
”Sign in with an external camera or fingerprint reader”
