Minibook X N150 Touchpad Twitch
SN: ZMinBXHY4H250300851
Purchased: Amazon(US)
June 2025
OS: Ubuntu 25.04/plucky
Hi Folks,
I’ve noticed a jitter/twitch with my touchpad. When I am using the touch pad and I am dragging my finger across to select something and then leave my finger on a spot on the touchpad, I can visibly see the mouse cusor jittering/twitching back and for about 15-20px. I think* the touchpad may be registering additional input from somewhere. I suspect this as the bottom right touchpad, when clicked pushes down and back smoothly, however the bottom left when clicked, has a feeling of resistance/stick, in the sense of it’s almost like it’s catching on something.
Has anyone ran into this before, and do you have any advice? I thought I’d throw this out before trying to open up my Miniboox and disassembly the various layers to get at the touchpad to take a look.
Thanks All!
SN: ZminBXHY4H241200250
Purchased: AliExpress (France)
June 2025
OS: Ubuntu 25.04
I am experiencing the exact same issue with Ubuntu 25.04 with a N150. I didn’t use Windows 11 but didn’t notice any issue with the trackpad there I still have Windows on my drive so I could double check.
An important point though is that this jitter issue is not always there. It stays for a few minutes and then goes away until it comes back. I plan on testing with Ubuntu 24 or maybe other distros to check if the issue is gone. I will report back here when I have time to do so. If you find any solution for this please let me know !
Good luck with this!
Can you guys write to service@chuwi.com and send a video of what is happening? if two people have the same issue, probably there are more and we need to look into it.
SN: ZMinBXHY4H250301106
Purchased: don’t recall
May 2025
OS: Fedora (latest LTS), Pop OS, Debian Testing
Hi Guys,
I’ve been having the same issue. Mine is also the N150 model. Nothing seems to really help and it goes away eventually but comes back.
I am yet to try on Windows as I went straight to linux. I’ve tried many distros as mentioned above and experienced the issue on all of them so I don’t believe this is distro-specific.
If the problem persist in Windows you can write to support. If its only in Linux and other OS we dont give support to that . We apologize.
Hi all.
I seem to have solved this problem. reading this article I tried the steps they mention to add hysteresis.
I’ve been testing for the a few days (this has been my only laptop for the past week) and I haven’t encountered the issue once.
I followed that guide and found it’s not fully flushed out, although it was very helpful. I ended up with some different adjustment values for the hwdb.d entry for the touchpad after doing some measurement and testing. I’m going to run these new values that for a bit and if it works, I’ll put in a request to have the values updated upstream.
If anyone wants to test them, edit the following file and overwirte the entry for Chuw with this
/usr/lib/udev/hwdb.d/60-evdev.hwdb
evdev:name:XXXX0000:05 0911:5288 Touchpad:dmi:*:pnMiniBookX:*
 EVDEV_ABS_00=:::25:10
 EVDEV_ABS_01=:::25:10
 EVDEV_ABS_35=:::25:10
 EVDEV_ABS_36=:::25:10
Is this solution still working? I am thinking of installing Ubuntu 25.04 and want to be sure before I make the dive.
Thanks.
Hi @cossen I’ve only been testing for two days so far, but it seems to be doing pretty well for me so far. I’d reccomend giving it a shot on Ubuntu 25.04, since that is what I’m running as well. (Though to fairly note, I am also testing the experimental setup with hardware backed encryption, since I had the time to tinker with it.
The only thing I’d also recommend you post install, is grab GNOME Tweaks, and also add these to your install.
sudo apt install libinput-tools && sudo apt install libinput-bin
I will likely attempt as time allows put together a write up of the things I’ve done so far to customize my install, but not making a promise on that yet.. :smiley:
I think Chuwi would REALLY benefit from putting forth some R&D hours to ensure flawless Linux support out of the box for one or two of the main distros, since many people seem to be buying these and immediately dropping linux on em, however I digress and have gotten on a tangent, since this is about Touchpad jitter.
Thank you so much for the feedback helpful tips. It is really appreciated.
Thank you all for the feedback. I did implement the solution posted by jld ant it was already better. I will try the PlywoodHammer one as well when I have time but these are very promising. Thanks again for your help.
Well, after trying both methods I can’t seem to get rid of the twitching… Any news on your side? Did your solution work for you?
I’ve since upgraded to Ubuntu 25.10, but I did notice that the touchpad driver got named, so my file/section now reads this:
# Chuwi MiniBook X
evdev:name:XXXX0000:05 0911:5288 Touchpad:*
EVDEV_ABS_00=::10:25:10
EVDEV_ABS_01=::10:25:10
EVDEV_ABS_35=::10:25:10
EVDEV_ABS_36=::10:25:10
Give that a try?
PlywoodHammers above settings worked for me on a Fedora build with KDE Plasma, however there’s an ever so slight lag when moving the mouse, like i am dragging the cursor through honey.
I’ve got Ubuntu’s Touchpad Acceleration turned on, not sure if Fedora has a setting to also turn that on? My touchpad always felt like it took to many swipes/drags to get across the screen without acceleration on.
For those who are wondering…
EVDEV_ABS_<axis>=<min>:<max>:<fuzz>:<flat>:<resolution>
++ fuzz (10) Noise filtering threshold.
If too low → cursor shakes | If too high → small movements ignored
++ flat (25) Deadzone size.
Too large → sluggish feel | Too small → micro-movements register
Feel free to adjust and see what works best for your setup. If you want to dive into the values yourself, chatgpt actually does a good job explaining it in depth and can walk you through changing those values if you need extra help. If not, you can reach out and follow up, and I’ll give it a shot.
I wish only the tp was glass/premium plastic one… I really cant use device that much bc of it on Linux…
Had the same issue with my Chuwi Minibook X — built this to solve it:
Windows tray app that filters touchpad jitter using direction-change detection. Single .exe, no dependencies.
First release — feedback welcome via GitHub issues.
A quick update on my fix, since there was a package update I pulled down that killed my custom settings. I also realized I had the posted the incorrect field order when it came to the config, and needed to correct it.
To set this up without having to worry about updates killing your override, do this instead.
#Create a standalone override for the touchpad
sudo nano /etc/udev/hwdb.d/99-touchpad-fix.hwdb
#Setup the override
# CHUWI MiniBook X touchpad
# Format: min:max:resolution:fuzz:flat
evdev:name:XXXX0000:05 0911:5288\*:dmi:*:pnMiniBookX:*
EVDEV_ABS_00=1:1156:14:0:20
EVDEV_ABS_01=1:619:14:0:20
EVDEV_ABS_35=1:1156:14:0:20
EVDEV_ABS_36=1:619:14:0:20
Restart to apply the changes or run
sudo systemd-hwdb update
sudo udevadm control --reload
sudo udevadm trigger --action=change /sys/class/input/event5
