I just got this minibook yesterday and it was fine until I did a windows update and now the keyboard is out. I’m new to this and have no idea what I’m doing.
On the Chuwi site you can download the drivers for your unit and install them yourself. I would re-install the key board driver and see if that works. What operating system are you using. Windows 11 ? Windows 10 or maybe Linux?
You can try these drivers
Exact same issue here. I reinstalled Windows using the Chuwi image. Everything works fine until Windows updates. Then the keyboard does not work correctly. Did any of the drivers fix the issue,? Thanks
