Need BIOS update for CoreBook X (i5-8259U) — battery not detected in Linux
I have a Chuwi CoreBook X with Intel Core i5-8259U processor and I would
like to install Linux (Ubuntu/Linux Mint) on it as my primary OS for work.
Unfortunately, the battery is not detected under Linux — the system runs
on battery power, but the charge level is never shown and there is no
battery icon. This is a known issue caused by a broken DSDT table in
the BIOS.
I have read on this forum that updating the BIOS to version 2.20.1275
(or newer) fixes this issue. Could you please provide me with the
correct BIOS file for my specific model?
My device details:
- Model: Chuwi CoreBook X
- CPU: Intel Core i5-8259U
- Serial Number: JCorBXIW1H211106920
I am attaching a photo of the label on the bottom of the laptop.
Thank you in advance!
You had this problem in Windows.
@manonegra222
I found your reply in another topic where you mentioned you can locate
the BIOS file if provided with a reference serial number.
My serial number is: JCorBXIW1H211106920
My current BIOS version is: 2.20.1271
Could you please check if you can locate the correct BIOS file
for my device in your database?
Thank you!
