No data transfer to Hipad X
Hi
I have recently bought a new Hipad X with the intention of using it as a dedicated drone controller for my DJI device. However, upon trying to connect it to the controller via USB C cable, it will not connect and seems to vibrate and beeps repeatedly
I have also tried to connect other devices (another Chuwi Gempad, an external HDD) and cannot get any data connection to those either. I have tried all devices with several different USB C cables, and also attempted to cut-back one of the plastic sleeves on one, as I see this was a potential solution for another similar Chuwi tablet issue.
Is the USB C port simply for charging? Because if so, then this tablet is not fit for my purpose and I will be returning it
Please advise - thanks
Great support response. Guess I’ll be filing that product return after all
Hipad X 6gb brand new here.
Can’t connect to PC (nor Mac) , reinstalled lots of Android ADB drivers, nothing. I have tons of MP3 to transfers I need for work.
Please help!
Hi @DJIMark , please read my answer here
https://forum.chuwi.com/t/on-connection-to-pc-hipad-x-folder-is-not-writeable/30076/2?u=dcabale
Does this help?
