On my Hi10X the usb-c ports does’t works well. I can charge a phone with it (usb-c - usb-c cable), if I attach an external drive (usb-c OTG) the drive led is lit. But in neither case have data connection. I cant use it for ped drive, etc.
Is it a general problem, or is there a solution for this?
(I have the original chuwi windows system, with no driver modifications)
Edit: any devices I connent, make no visible change in windows device manager
You are lucky I just connected mobile usb charger to port C of a brand new Chuwi U book pro and it died in two minutes.
Something is wrong in the circuit design.
With Chuwi no hardware or software modifications or upgradations are advisable.
Only the original charger to be used. Back up the data before switching it off And each time to pray the God be fire switching it on. Any time, anything can go wrong.
