I’m trying to record some audio but the only input selection is microphone. There isn’t a stereo mix selection. How can I enable stereo mix to make the selection available in Sounds?
John McCrae
musclemac2@gmail.com
John McCrae
CHUWI Hi10 X, 10.1" Tablet PC with Keyboard
Both Windows 10 and 11. Just did an upgrade. Thanks
Hello
Try following:
On the Playback or Recording tab, right-click on the empty place.
Select Show Disabled Devices, and Disconnected devices.
It should reveal Stereo Mix.
Right-click and enable it.
My laptop is in Portuguese but the path is the same.
Please let us know if it worked.
Thank you for your suggestion but I had this already checked with no luck.
