No WIFI Hi10Max and GemiBook Plus
I have reinstalled Windows 11 on my HI10 Max and my GemiBook Plus, and now on both devices, I cannot get a wireless Wi-Fi connection.
Additionally, on the GemiBook Plus, the trackpad does not register any input (I currently have to use a mouse).
The serial number for the Hi10Max is: ZHiMaxHZ1H250401750
The serial number for the GemiBook Plus is: XGeBPLIC4H250302506
I’m assuming it’s a driver issue, as the option to connect to a wireless network is simply not an option. I bought both devices from www.chuwi.com about 2 weeks ago.
I have a similar problem with my chuwi 10x
I found the drives on one of the forums,
https://www.mediafire.com/file_premium/9vgs0bqxtq0uzvq/Hi10Max_Drivers_Win11_X64_V0.1_20240605.zip/file
If you go to Device Manager and see which drivers are missing, then use the feature to search within a folder. Select the folder, and the drivers should be found.
Did you install the correct files?
This is your OS from CHUWI
Hi10Max
https://www.mediafire.com/file_premium/3aprsnsl5oii3k7/Hi10Max_X1_CW129_12%25E5%259C%258B%25E5%25A4%25A7%25E8%25B2%25A8OS_2025.04.08.zip/file
Drivers
https://www.mediafire.com/file_premium/oznv3pnutby4150/Hi10_Max_N150_Drivers.rar/file
GemiBook PLus
https://www.mediafire.com/file_premium/anw0tz1j37eu1kf/GemiBookXpro%2526PLus_US_%25E8%25AE%25A2%25E5%2588%25B6%25E8%25BD%25AF%25E4%25BB%25B6.rar/file
https://www.mediafire.com/file_premium/rrfoks0p6sa4ykt/GemiBook_Plus_%2526Xpro_All_Drivers.7z/file
I dont know why everybody reinstall Windows in a just new computer, the WIndows that comes is the most updated one. Then these problems appears.
