Hi there,
I just received my brand new HiPad X, and wanted to connect to my Windows10 PC, using the provided USB cable.
- On the cable plug-in, the Windows file explorer shows me only an empty “HiPad X” folder, as shown here:
- Unfortunately, there is no way to put anything into that folder, or to watch the HiPad’s internal file structure. It looks like a default folder authorization settings to be set on the Tablet prevents from transferring files to it.
→ Does someone know how to enable that, and if no specific settings regarding folder authorizations does exist, how to transfer data between my HiPad X and my PC?
Thanks for your help.
