RZBOX not working. No Video signal
Good day. My RZBOX not working properly, power led OK, cooling system OK, usb power OK, video signal not OK. I think some of BIOS setting are corrupted.
Please send original BIOS image for RZBOX with AMD ryzen 7 5800H
SN : ZRZBOXXIY1H230100566
Have you reinstalled or changed your Windows version ?
Have you changed any BIOS settings ?
You need to contact support.
It could be a hardware failure., How old is the computer ?
Hello, PC aproximatelly 3 years old. I don’t know about changes in BIOS or OS reinstallation.
Daughter use this PC, she sad switch off at the evening and PC not start at next day.
How to contact with support?
Did you ask your daughter if she made any changes or installed anything?
Have you tried to enter the BIOS?
The BIOS is usually not the cause of problems when the computer won’t turn on.
You can try booting into safe mode.
from the Chuwi website
No image on monitor - can’t access to BIOS
When you try to turn it on, you either notice it doesn’t turn on or there are no signs of it turning on.
PC switch ON, power LED on, CPU coltage 1.2 volt. Maybe have some issue with BIOS or Video signal IC
