Screen does not rotate automatically
I bought a Chuwi Hi10 Max two days ago. SN: ZHiMaxHZ1H250302476. After the initial setup with Windows 11 23H2, the automatic screen rotation worked. After the update to Windows 11 24H2, the automatic screen rotation no longer works. I have already reinstalled the drivers and it did not solve the problem, I can no longer go back to the previous version of Windows. I need a solution.
I am having the same issue, tried reinstalling drivers and no luck.
I’ve tried everything, I recommend going back to 23H2 through Windows itself or downloading the ISO, the problem is in 24H2. Chuwi has to update the driver for this version!
Same here on the Hi10 Max N150. I reverted to version 23H2 and it works.
Is there already a solution to this issue?
Hi. I’m new here. I’m thinking of buying the H10 Max. Has Chuwi released updated drivers for this issue or is it still a problem?
You can ask Chuwi; you can ask what the return time is.
