Hi all
I don’t know why but I have a lot of problems with sound levels. I hear videos from youtube or anything else very low despite having the maximum level on the speakers…
Any idea about where the problem is?
The problem with the sound is that the UBook Pro has downward facing speakers. If you are using the UBook Pro in laptop mode (keyboard attached), you can try a little trick. Cup your hands to the sides of the UBook Pro behind the screen (see photo). You should hear an increase in sound. The key is to reflect the sound from behind the screen to the front. I am still thinking about how I can do this with cardboard or something.
Hello good exact the sound effectively goes backwards, with the hand it deviates forward the sound wave, with some cardboard that is put when you fold the stand behind ear type greatly improves the sound, another way is to install dolby teatre sound, improves much the sound.
