I installed an SSD (this one)
BIOS recognised it. I installed windows. Everything seemed to be fine (also the speed has increased significantly) but now sometimes the SSD is not recognised and I go straight into BIOS…
I think it is an SSD issue. You should check that it makes good contact in the slot and that it has no movement and is properly secured with the security screw.
Once these checks are done, you should perform an SSD drive error check and finally a Windows startup repair
