Hi everyone, I recently bought a Gemibook and I’m surprised to note that it makes noises very similar (and definitely perceptible even a few meters away if in absolute silence) to those of a task with an HDD. I tried to do several tests including benhcmark, and all the tests indicate an SSD, albeit with a rather slow speed compared to the average (I don’t remember how many mbps, if necessary I can redo it to give precise data) and I don’t understand how fixed components can make such loud noises, unless coils have been mounted and/or the SMD pieces have been correctly positioned on the PCB. Do you have any more plausible explanations? Do you know if it’s normal? Does it happen to you too? With Chuwi Herobook nothing similar had happened to me!
Thanks in advance and sorry for my English… I have the flu and I left the translation to Gemini
coil whine? check if charging will increase the sound.
another idea is interference with the speaker coils, which i think is unlikely. increase or decrease volume if it has effect.
That does not sound normal.
But if its only GemiBook that product is discontinued and old. So we have no way to check it here.
If you just bought a new one, GemiBook Plus , you could return it for replace before 14 days.
