sorry for bothering, after a battery replacement my hipad x is stuck on boot on chiwi logo.
recovery mode is also stuck.
fastboot is also not working as expected, connected to my laptop is swinging up and down the usb connection.
S/N Q128G210503968
Hi thanks for helping,
i keep the device turned off as the procedure request, unfortunately when i try to flash the tablet it wont startup at all, it remain shutted.
any advice?
To flash the tablet it is necessary that it be in DNX mode because when it is turned off it will not be able to receive the software we are trying to install. Try activating DNX mode by pressing the power and volume down buttons at the same time
