Where can I buy touch screen replacement?
AfterSale reply me:
“The screen of Hi9 air is out of stock and has stopped production.”
I need only touchscreen, glass is broken, someone can help me?
LCD Display works fine
But touch and display are glued together so you can’t replace it without separator.
I can separate them with an Hair Dryer?
You can detach the display module (display + touch) with a hair dryer, but you can’t separate the touch from the display.
You need something like this https://www.youtube.com/watch?v=uviyYJ58ib4
