Upgrade HI10MAX from win11 home to win11pro
I want to upgrade win11home to win11pro. Will my hi10max tablet handle it? Will there be any sluggish behavior or additional glitches in operations?
Why ?
Are you having a problem with Windows 11 Home ?
No… There are a few glitches, but I presume it is either my win11 learning curve or my touch screen learning curve. I come from a 13 year old win 10 Sony Vaio 16" fx series… It is a beast and still working perfectly. I also have to figure out if I can use a powered dock to connect to this tablet.. that can handle a cd/disk drive, an external drive and some flash drive devices (which the Vaio had integrated). I feel like I am in school taking a new course ha.
You can look for differences between Windows 11 Home and Windows 11 Pro.
  • My suggestion is to use it as is.
To upgrade to Windows 11 Pro, You must have a license and complete the upgrade process.
WOW Hi10 Max is beast, i just put bazzite Linux on it and w11 enterprise next to his original w11 home and it’s running all those systems without any problems,i am just testing its battery life so i can choose one of those OS to be finial decision. Drivers provided in support section are all good so CHUWI you did great job <3
thanks for the tip
