I have a USB 3 RJ45 adapter that also has 3 USB extensions in it. For months it worked fine, but recently, whilst it still works for things plugged into the 3 USB extensions, the CHUWI no longer recognizes the RJ45 network connection. The adapter works fine when plugged into another laptop. I’ve tried uninstalling and re-installing the drivers. Also when I plug in a similar one into the USB-C port it works fine (though due to the old CHUWI USB-C issue the battery drains, so this is not a permenant solution.
In summary it seems the laptop is not recoginzing the RJ45. HELP please.
