Whatsapp cam error
video call with WhatsApp the camera is horizontal. How to correctly set it to vertical.
videochiamata con WhatsApp la fotocamera risulta orizzontale Come fare per impostare correttamente in verticale
@manonegra, maybe you know this :wink:
I have the same problem.
Is there a solution to this problem?
well, I have the same issues with this … also when I share a screen in WA Web Desktop PC, the image comes up with a horizontal. hopefully any one has experience to solve.
can you guys send a video of whats happening would be hard to explain to tech by words.
Allego foto del problema con le chiamate watshapp.
Grazie
hi all, is there a solution for this issue?
Does it happen only with whatsapp or with all the programs in which you use the Cam?
Succede solo con WhatsApp con altri programmi funziona normale ,
Only with whatsapp. No problem with other apps
Pada Kam, 2 Jan 2025, 15.36, Maria Isabel via CHUWI | Official Forum <notifications@chuwi.discoursemail.com> menulis:
Tech is checking
News fom cam abnormally rotate wathsapp ?
Oggi Ho scaricato un nuovo aggiornamento di Microsoft Windows 11 e con mia grande sorpresa quando ho ricevuto una chiamata di WhatsApp la webcam si vedeva perfettamente finalmente risolto il problema.
I’ve had that too!
Di quale aggiornamento si tratta?
Which is the windows update that solved the problem?
