Hello, here is the version of my Gemibook pro:
[CHUWI Ordinateur Portable GemiBook Pro 14" Windows 10 Intel Celeron N5100 Léger Notebook avec 8 Go de RAM 256 Go SSD 2160 x 1440 Pixels IPS Display C]
I would like to add an SSD, and know if it is compatible? →
Thank you
Hello. - Hello.
I am using the same Gemibook pro N5100 as you.
As far as I can tell from the specifications of the product you are purchasing, it should work fine.
By the way, I am adding the following products
Hello, just search for an m.2 SSD with SATA. NVME is might be faster but it will wont work! like this:WD Blue 2TB SSD SATA peace
