[Android] Help! Booting up Android
I need help. I managed to install a Linux on Chuwi with dual-boot bios. The BIOS would allow booting .efi only from Android and Windows. I was not able to manually insert boot entries (searching .efi files in EFI partition), so to make a workaround, I put the Linux EFI file into /efi/Microsoft/Boot and I was able to boot Linux using Windows .efi filepath.
I installed RemixOS 3.0 and I want to alter its efi file in the same way so I may boot up choosing the Android option. What’s the filepath for Android .efi?
