Android OS for Chuwi HI10 Air
I have a Chuwi HI10 Air. The Windows 10 is running slow and doesn’t wake up when it in sleep mode.
So I decided to install Android for Chuwi HI10 Air (I tried to install Android x86 all versions (Android 9, 8.0, 7, 4.4, 4.0, 2 (https://www.android-x86.org/) ) But all that Android versions is won’t boot for me (Screen freeze forever…) :(( What can I do :(( Please help!
Can anyone have an Idea and method to install Android for Chuwi HI10 Air ? Thanks.
Here is a guide. Beware, flashing bios can brick your device.
can it dual boot android and windows 10 ?
I don’t know, you can ask @arxym for more information.
Do you have BIOS for Chuwi Hi10 AirQ64G19100XXX ?, I have downloaded BIOS file and flashed, it says " ‘efi…’ is not recognized as an internal or external command, operable program, or batch file.
Contact aftersale@chuwi.com for right bios file.
