Audio jack static noise
My Tablet has has massive issues with a static noise that almost sounds like coil whine when plugging in headphones. The speakers do not have this problem. Has anyone else experienced this and does someone know of a fix?
Yeah have the same issue, prob. Its a interference signals which came along the case. Dont plug your connection to deep and it wont come up. Iam not Sure how you can fix it without that.
Not plugging it in all the way doesnt help, and I dont really see how it should help. Maybe the preamp sucks. I might try a USB to Aux in the next few days, but that solution is mighty inconvenient.
Try installing the Realtek HD Audio Codec Driver R2.81. The lastest version R2.82 has some known bugs.
Just did that, but it makes no difference :confused:
