Chuwi freebook i3 1215u
After trying multiple modifications to the sensor configuration on my Chuwi FreeBook, I finally found that simply deleting the system-wide hwdb file fixed the issue.
If you’re experiencing incorrect accelerometer i not recommend this but you can, try the following steps:
This resolved the issue for me. It seems that some previous configuration changes might have caused the incorrect rotation in the first place.
If you’re also using a Chuwi FreeBook i3 12150u with rotation isue, try this and report back with your results! I’ll report again if I reinstall the OS to confirm the fix.
