I removed the battery because it swelled a lot, and now I’m using it without an internal battery, just plugged in, and I have a speed problem, it limited the processor speed to 2ghz, the notebook is very slow, it would have some configuration What can I do until the new purchased battery is delivered?
Were you able to use it without battery, only with charger?
How is your energy setup at Windows?
Yes, only with charger.
i’m using it in high performance in energy setup, but my cpu is always limited at 2,30ghz.
Hello again,
Got the impression laptop wouldnt work without the battery but this info is good.
These are the BIOS setup I have:
And these are the max speed I’m having
Check if yo have the same.
I’m using USB-C for powering.
I wonder if it’s due to the missing battery.
I would say, do one more test. Power it using USB-C with a 65W or higher charger.
Yes, i thinks it’s the missing battery, when i got the new one i will post an att here. Have tested with usb C powered in my dell monitor that can deliver 90W, but is the same 2ghz.
Quick Question…
Where did you find available the battery to replace?
I find it in aliexpress
Could you share the link after, and also when you receive, the feedback
Hey,
Thanks! It´s a bettery without all the frame and the screw parts. I hope this works fine. Please share how you manage to fix the battery inside the laptop after.
After a long time the battery finally has arrived. And the laptop is now working properly, the cpu can reach the full potential of 3.8ghz. It was the battery after all.
Great to hear.
I’m looking forward to get the same battery. One question, how you manage to fix the battery since it does not come with the frame and screw parts?
I removed the old battery frame and the screws and put it back on the notebook, but without the battery which caused the problem. And when this battery arrived, I just mounted it inside the frame and placed the connector on the notebook.
