Bricked tabalet Need file and help
CWI 529
PQ64G42160800716
I think it is hi10pro
Both android and win did not work.
How I reinstall everything again?
Thank you
Get a usb-C to USB-2 adapter and plug in an old wired usb keyboard, and get a usb memory key.
Use the regular methods to access the bios
Change the “fast boot” setting in bios so you can better control the boot with the keyboard
On a separate windows machine, build a USB Windows 10 installation key
Android doesn’t work in my experience on the H10Pro, only windows.
