embb
August 20, 2020, 3:45pm
1
I’ve just got a new CHUWI UBook Pro from Amazon.
Looks really great but then could not install any Linux distro.
Anyway I gave up on that and install my company Windows 10 enterprise edition.
Everything is good using those drivers from here https://onedrive.live.com/?authkey=!ADxrDB2frGHwNLk&id=FC1F543E3FBD4AAA!22701&cid=FC1F543E3FBD4AAA
But I cannot get my camera to work. Driver looks good on windows 10 but is not detected.
Attached is my serial number picture.
Regards
Eduardo
embb
August 20, 2020, 4:06pm
2
Here are drivers showing ok on windows device manager:
You can try the Intel Camera Sensor driver.
Here is one from a Lenovo site that might work for you.
https://support.lenovo.com/th/en/downloads/ds120517
Or from the Microsoft catalog:
http://www.catalog.update.microsoft.com/Search.aspx?q=OV5648
http://www.catalog.update.microsoft.com/Search.aspx?q=OV2680
You might want to sort by Last Updated.
I am currently using the 30.14393.9681.3190 version
embb
August 21, 2020, 8:05am
4
Thanks for your feedback. I saw this same info on another topic and already try that… all drivers seems to work but both cameras are still not detected… I starting to think I have a faulty device and will need to return it to Amazon.
Eduardo
Do you have any Unknown Devices showing up in your device manager?
If not, you might have a faulty camera sensor module and probably best that you return it before too long.
embb
August 21, 2020, 9:56am
6
No, all devices are good so I suspect that is really the case…
I am having the same problem with ubook x
You guys write first to service@chuwi.com as maybe there are other files for camera, if not, then return. And that model is discontinued, is an old one. So if it breaks probably we wont be able to repair.
i wrote service two days ago. no response yet.
The tablet worked fine with windows 11 pro until the last update of windows. i had another problem with the touchscreen and the hid2c driver.
This problems must be solved by the Chuwi Team, because its a driver problem.
