I have problem booting my UBOOK Pro when i get it from Day 1, i wrote to your customer support but no reply but i manage to boot up the windows but now my camera can not be detect. Do you have driver other than Camera Driver?
You can try the Intel Camera Sensor driver.
Here is one from a Lenovo site that might work for you.
https://support.lenovo.com/th/en/downloads/ds120517
Or from the Microsoft catalog:
http://www.catalog.update.microsoft.com/Search.aspx?q=OV5648
http://www.catalog.update.microsoft.com/Search.aspx?q=OV2680
You might want to sort by Last Updated.
I am currently using the 30.14393.9681.3190 version
Camera chuwi ubook pro của tôi bị lỗi. Làm sao để cài đặt ov5680 và ov2680.
tôi đã cài ov5648 và ov2680 phiên bản như bạn. nhưng camera của tôi vẫn không hoạt động. tôi phải làm thế nào. làm ơn giúp tôi!
HI All who have a problem with the camera not detected …, i ad this in the past too, tried all possible, no solution , a sudden worked again after a win. update …for a while , another update and camera not detectable again , until i also update with driver booster from ioit the gaming drivers (i am not a gamer …but) WORKED again detectable …UNTIL today the update INTEL CONTROL LOGIC ( 1) and camera again not detectable and error driver message on the 2 sensors for it in device manager.
SO DO NOT UPDATE INTEL CONTROL LOGIC as that one did it go wrong as it was the only 2 drivers driver booster suggested to update , they seem not to be compatible with chuwi camera
