Can I leave my laptop plugged-in while using it?
Hello, so I recently got my laptop Chuwi Corebook X Intel Core i3.
And I was wondering if I can let it stay plugged-in while using it even if it reaches 100%?
Does the laptop automatically stop charging and uses the electricity instead when it fully charges?
If yes, is there a setting for it?
Yes, it should even be safer to do so than to plug it out when the battery is full. You are sacrificing battery longevity by doing so. A better way is if there’s a setting to limit charging to something like 80%, but AFAIK no Chuwi laptop has it. Still, keeping it plugged in is a better option than using battery when unnecessary, i.e. you have access to power socket.
