I am actually want to know in details that how the battery will remain good
My laptop is Codebook X Pro, i have purchased it in 4 days. I’m concerned about the laptop battery.
Should I use the laptop with connected the charging port or without connected the charging port or is there any issues if I connected the charging port even after 100% charged. Does it damage the battery?
Is the laptop charging automatically gets off when It’s reached at 100%?
I am actually want to know in details that how the battery will remain good.
Thank you.
@manonegra222
It’s a good question, since the life of a battery depends largely on the use that is made of it and the conditions under which this use is made. Nowadays, batteries have protection systems so that they can work while they are plugged into the power supply and are not continuously starting and stopping the charge, but it is also true that during the charging period the battery acquires a higher temperature, which is an enemy of the battery’s durability over time.
My advice is to use the laptop rationally and without causing the moments of stress that occur when using the laptop with a charge of less than 15%, or performing complex processes that increase the temperature of the equipment when it is charging.
When it is disconnected from the charger, normal use.
Things might have changed over time, but my understanding is that battery should not be charged to 100% and it should not be dropped to 0%
Keep it between 10% to 95%
Charge in one single charging action from 10% to 95% and stop. Do not intermittently charge it as and when you like it!
This helps to calibrate the battery better after 3 - 4 charging cycles and the wearing of battery slows down and it can last relatively longer.
Avoid keeping ON laptop on sofa or bed with soft mattress. This activity in a way may block the bottom air vents and can increase the internal temperature.
