What happens if you insert the charge into the USB 3.0 port of the chuwi Hi10 x tablet? Does it have protection? Can I charge my tablet via the USB 3.0 port with normal charging?
Since the load and data contacts are different, nothing should happen, but it is best not to experiment.
If Chuwi says it is charged by a port, that is why the battery should be charged
