Greetings, I am thinking of installing Chrome Os flex on my Chuwi HiBook Pro, apparently it meets all the requirements. Has anyone done it? In case it goes wrong, would it be possible to restore it to its original state with Windows 10?
just try it first from usb if everything works. sometimes sound or wifi does not work. if you’re ok then you can install on disk, replacing windows.
you need to backup windows drivers and your data, if you want to restore windows back.
another option is to install linux in dual boot mode with windows first. then from linux you can install chrome flex using the linuxloops project. then you dont need to restore windows.
