Hi, I purchased a Chuwi Aerobook 13.3 on Amazon, it arrived today. I immediately found a problem with the battery. I put the PC in charge, but as soon as I turn it on, it turns off in less than 15 seconds. A red (flashing) light is currently on charging. What does it mean? Are there problems with the battery? What should I do?
The red charging light should be steady, not flashing. When the light ends it turns white. If your AeroBook is not working, you must return it for an exchange or get a refund
Thanks for the reply, I have already made the return and request for replacement. I have read on this forum that many users have had problems with the battery of the Chuwi Aerobook, is there anything that can be done to improve the battery of this model?
