Honest review of Chuwi Corebook X 12450H after 6 months
My honest review of Chuwi Corebook X 12450H after 6 months of use.
I’m a hardcore Asus fan and until this notebook i’ve been using only Asus computers for like 15 years. Yet, the inability to find a new generation Asus computer with a glossy IPS screen, and my would be computer being sold only as OLED (the Asus Zenbook Space Edition that i was considering for a long time) i started looking for a computer with a similar H-series processor Intel 11th Gen or higher but with IPS glossy screen and stumbled on this one.
So here is my experience:
The positives:
- This laptop has one of the best screens i’ve ever seen on a mobile computer and that’s not just the resolution. It’s the aspect ratio, color contrast (whooping 2500:1!!!), eye comfort, no PWM (f*** OLED), angles of view, pretty much everything besides the brightness which could be up to 20% higher and 20% lower at its lowest settings, but that happens very rarely. The screen even reclines 180 degrees. Well done Chuwi!
- The keyboard on this thing is absolutely astounding; it feels like a mechanical keyboard and it’s the closest to one that i’ve ever found on a notebook. You can type on it for hours without getting tired, the clatter has a very pleasant sound and the keyboard has no flex at all. Congratulations.
Btw i’ve also tested a new-gen Corebook X with the same processor but USB-C charger and the keyboard wasn’t that good and the screen wasn’t that great either. You can relay your own experience, but my one belongs to the first generation with the barrel charger. - Silence: this notebook is totally silent unless gassed to the max. That was one more surprise for me since generally lower-brand notebooks tend to have either horribly configured fans or fans of low quality. This one is perfect. As i’m typing this, i hear absolutely nothing else than the sound of the keyboard.
- The laptop charger is extremely small and light which with the notebook already being light makes for a breeze to transport around. It makes for a real ultrabook. One more great move by Acer/Chuwi.
- The blue indicator LEDs are perfect at night and better than white; Chuwi also put an actual bi-colour LED for charging!!! F*** you Lenovo!!! Since switching to Windows 10 the power button stopped blinking on stand-by, while it was under Windows 11, didn’t found how to fix that.
- All the keys are perfectly placed, especially the separate PgUp PgDn, except the (too) small right shift key.
- I didn’t speak of performance since it’s obvious for you, this processor offers a near-desktop like experience
- Separate respect for the switch-off LCD button at F1
- The speakers produce a respectable sound but…
(and here come the negatives)
…there is no good software from Realtek that would have an equalizer like found on Asus laptops, at least i wasn’t able to find one (you’re welcome to advise). Also, out of the box one speaker would not work, it needs the exact driver for this notebook which wasn’t easy to find, the usual Realtek or Windows drivers won’t help
- This thing via USB charges SHIT. I left my phone plugged-in for like an hour, only to find the same percentage of charge, sometimes 4% lower, sometimes 4% higher but otherwise identical. If Wi-Fi hotspot is used on the phone the notebook is unable to even keep a stable charge, no matter the USB port. Again, i found no configuration to mitigate this and according to all forums ‘this is normal’. This happened only once for me on my previous Asus UX534FTC, otherwise all other notebooks Asus and others were able to perfectly charge the devices, some even while the notebook would be turned off.
- Back to the USB issue, the USB ports don’t support thunderbolt what would have elevated this notebook to a completely new league with eGPU support
- The keyboard as good as it is has one strange flaw: THE BACKLIGHT BRIGHTNESS IS DAMN TOO BRIGHT. It honestly hurts my eyes at night, especially the light between the keys, so i stopped using it altogether pretty much. It wouldn’t cost less to put a backlight that is less bright than that LOL.
- Battery life is abysmal but you know that already. Putting the TDP to low in the Intel Framework configuration made the computer unusable and run like an Intel Atom or Celeron from 2019. Things got better when i set it at normal but lowered the highest percentage usage (currently around 60%). This way the laptop lasts 4-5 hours with Wi-Fi and everything.
- It would have been much better if Chuwi added a second NVMe slot, instead of a second RAM slot. Two RAM slots is overkill. One RAM should have been better on the motherboard and for the slots to allow both RAM and SSD expansion.
- Out of the box the hinges were so tight that i thought they were gonna break, like they used to on the Asus UX303LN series. Also, since they come in an assembly, they can’t be just mechanically twisted and played around. One shop asked me about 100$ to fix the issue. Instead of dismantling the whole screen i’ve put there a decent amount of oil while rotating the screen and now they work perfectly.
- The cheapest thing about this notebook is apparently the case. Already after a few months it shows signs of usage on the palm rest and the keyboard, so i had to protect those areas, otherwise they’d look terrible in a few years or less.
- The rubber feet on the base plate closer to the hinge are also very prone to fall/glue themselves off.
All in all. there is nothing ‘unforgivable’ about this laptop even with all its shortcomings, which are mostly minor and easy to get around (the most unnerving of them is certainly the inability to charge devices via USB).
Some are down to cost-cutting, like others are clear mistakes that could have been fixed.
