Chuwi Corebook X R5-743OU/ i9-13900H. Battery
I have a problem with my brand new laptop (purchased on Feb.16,2026) because it charge too slow that it takes 4-5hours instead of 2hours. And the battery percentage stays on 94% and did not reach 100%. The charger also that I receive is not type C. I need some help about this
Take contact with seller,
First check your battery, use battery info program, and then try to calibrate your battery. Find on Google how to.
How you change your laptop with not a type-c charger?
