Chuwi Freebook does not switch between tablet mode computer mouse keyboard dont work (solved)
Thank you for your input. This problem is a big issue with this computer model and the impossibility of manually turning off the tablet mode in Windows 11.
I have a Chuwi Freebook with the very same problem. It goes crazy trying to detect when to go to tablet mode and when to come back from it, which makes it impossible to work with it.
I have just taken these steps you mention and the problem seems to be gone. I’ll post another message otherwise.
Thank you again.
An update on the issue, which frequently returned. Random switching tablet / PC modes was annoying. I think I finally resolved now by an updated driver which is suitable for Win 11. Found on this site. It is called MXC6655angle.
Hi everyone,
I recently purchased a Freebook 360, i3, quite happy with it until it done it’s Windows updates and the rest is history jumping from working keyboard to none… I’ve done the suggestions by ‘’@ Wortelstok’’ and it works a treat, I was about to give up on it…
ON the MXC6655angle drive update, I just used the latest version from the list, I hope that was correct.
