de nada. cuéntame si te sirvió al final
Hola Waldo, buen día!
Revisé cada dispositivo y todos tienen su controlador pero aún así sólo me funciona un parlante. Es raro, porque funcionaba y tampoco tuvo un golpe como para que sea un tema de hw. Seguiré investigando. Si encuentro algo lo comparto.
Gracias!
Enviado desde Correo para Windows 10
ya. es raro eso. puede que sea un problema del parlante y no del controlador. sí
Hello everybody.
Anyone know what the special key drivers are in particular. I am referring to the special keys, such as brightness up \ down, audio volume and off. Thanks in advance!
i used that update but now my wifi and Bluetooth doesn’t work at all and my wifi doesn’t even show in the device manager
but everything else is working as it should
Hello
Please send me the exact model and serial number of the computer. I will help you find the corresponding system files to solve the problem.
Thank you and best wishes
Chi for after-sales
gemibook with j4125 cpu and 8gb ram
that’s the product link from banggood
[S.R.1,517.33 38% OFF]CHUWI GemiBook 13 inch 2K IPS Screen Intel Celeron J4125 8GB LPDDR4X RAM 256GB SSD 38Wh Battery Full-featured Type-C Backlit Notebook Laptops & Netbooks from Computers & Office on banggood
https://banggood.app.link/ulmkNyoLMlb
here’s the video explaining my issue
GBook Y256G210701989
Será posible que me compartas tu iso ya que yo tengo el mismo problema y no logro solucionarlo
Hi Alex… Having same audio problem, you ever get a fix for the driver isue
Hey antoneyz,
I had the same issue for a month now. Fixed it buy downloading another ESAuDriver Device for example “ESAuDriver Device 12.21.15.169”. It also works on a “clean” Windows 10 or 11 installation. So what i did step by step was:
Create a Windows Bootable USB (Version does not matter)
Install Windows
Your touchpad and sound will probably not work. You can use an external mouse.
Instal Snappy Driver Installer (Will fix your touchpad and few other missing drivers)
Select Drivers for your Laptop and press install. After the first run you will see “need a restart” so restart your Laptop and do another scan. Repeat until there are no drivers anymore listed. -
Download the ESAuDriver mentioned before. After that go to “device Manager - Audio, Video and Gamecontroller - ESAuDriver Device - Update Driver - Search on my PC - available drivers on my pc - volume…\disc… (bottom right corner) - find the location you safed the downloaded ESAuDriver”.
Sound should work now.
Have a nice day everyone, hope that helps you!
Hope that helps you out.
you were having a laugh eh An4n4s. Cause its taken me 3 months to stop laughing. Or are you working for some software trapper… I hope not.
Hey Anto-Glas.
I was just bored and wanted to fix this issue ![]()
Did it work for you?
hello
please help me to find sound and touchpad drivers for Windows 10
for my device
GemiBook Pro
serial No JGeBkPCY1H220303489
thanks in advance
