Please help to detect the internal mic using Windows 11 all hardware are working except the internal mic.
Already solved my problem
Uninstall sst driver all of them if the device is not detected just restart
Install realtek audio driver manually at the device manager when the device is being detected
At device manager will detect another device twice
Then install driver Lapbook Pro Driver manually from he device manager
Internal Mic works @ Windows 11
Hope no more bugs to encounter…
hi
I’ve got the same problem.
I don’t understand what you are saying.
What is sst driver (where is it)?
install driver lapbrook pro manually. what does that mean?
can you help?
thanks
PHil
Could you please explain how you fixed it? I am having the same issue with internal microphone after win 11 update. Which one is realtek audio driver and how did you download it? Thanks
