hello, after install Windows LTSC, Windows dont install audio driver, i try the drivers from link MediaFire GLK but system cant recognize, i try reistall another window same problem, i downloaded the complete european image from chuwi and same problem.
i try downloaded from diver easy and 2 more software but i cant solve.
(note: before reinstall window, audio system working)
If you see in device manager ESAuDriver instead of Realtek audio device, then you have different version of laptop and standard drivers are not suitable for you. Try to contact with service@chuwi.com
same problem… I have tried everything.
I restored a windows image/copy from another Herobook Pro (where audio is fine) and it still doesnt work.
So this is very confusing because drivers shoud be the correct ones.
Please does anyone can help??
Thanks!
I have found the solution, Download the drivers from the link here . First, install the u1si02afcja0 driver then install Audio_Realtek_6.0.9038.1_W10x64_A driver. If an error states that directory cannot be created just press ok or cancel and try install again and it should work , Audio Driver Download
Muchas gracias por la información-
He conseguido actualizarlos los drivers de sonido siguiendo tus instrucciones.
Mi equipo es un herobook Pro 14,1" con Intel Celeron 4020.
Repito muchísimas gracias.
