hello i need help… my hi10air until yesterday it worked regularly it turned on but then not anymore … the power led on the keyboard flashes and nothing appears on the screen, not even the backlight goes, I tried to put a USB lamp and when turned on the lamp turns on and off in cyclically.
Has anyone had a similar problem? corrupt bios advice?
Hello, please provide the serial number and model number on the back of the machine, thank you
HI10 AirQ64G19114205 type CW1529
thanks for your reply
try pressing the fn + del or esc key when you turn on the tablet. If it doesn 't work, try pressing the power key and the volume at the same time. I hope it helps.
Dont change…can explain with more detail? Or have other suggestion?
I have the same problem
