chuwi gaming
chuwi gaming
Genshin Impact on Chuwi Hi10 Go
The android distributions with kernel versions 5.4+ run fine, but this is still not enough, because you need at least 5.15 to make the touchscreen work.
I was able to run the Bliss OS v15 distribution https://blissos.org/, but they have a maximum kernel version of 5.10
I cracked my Hi10 Go screen. I’d really like to replace it if possible, but I can’t seem to find any replacement parts specifically stated as for the Hi10 Go. Any leads?
I can’t believe you got Genshin to run on it! Around New Year’s Eve last year, League of Legends was just barely chugging along for me.
i wont trust other users on the public forum, i worry the drivers have virus.
HOWEVER, for hi10x, if i backup drivers by dism method,
when i reinstall the drivers, windows will check digital signature.
drivers from chuwi are signed.
if you people use someone else’s uploaded driver here,
pls make sure the drivers are signed (i.e. no warning when you reinstall them).
chuwi is good
it is you the user who should ask/know before buying.
chuwi is blamed.
btw, if NOT specifically told yes, you better assume no.
the cheap tablets are like condoms, like plastic bags.
broken, then dump and replace.
This file have password !!!
Another HID (Windows touchcreen driver) re-upload on gdrive, just in case:
