Since there isn’t a subforum for this device and the Chuwi support is lacking, i choose to write this megathread just to share my findings on how to get the best out of the Hi 10 GO.
Prepare to completely format your device (just to eliminate every chinese bloatware)
run ConfigUpdate from folder 2 OR if it swears and gives an error, first from folder 1, then from folder 2;
reboot. If someone should have the H7 updated diver, please feel free to create a download link for everyone else
GYROSCOPE FIX and other unkown peripherals (thix to @iuwu871 )
Download the official driver pack (is for W10 but it will work also on W11) here 456.62 MB file on MEGA
Unpack the zip;
go to Device Manager, select just the unrecognised devices and go to “search for drivers inside this devices” (or something like that, i’m going by memory);
select the path where you’ve unzip the downloaded archive and select “search also in subfolder”.
I think you can also add to the fixes: If the microphone does not work on win 11, go to the sound settings, additional sound settings (the “Sound” panel should open). Next, go to the recording tab, go to the microphone properties, the “Advanced” tab. Uncheck the box next to “Enable additional sound tools”. It is Google translate text (My native lang is Rus).
Citazione
Nice work briani_davide and Devint. It seems you care more about clients than Chuwi.
I´m strugling to get the bios version to N5100 model.
Whan I succeed, I´ll post the link here.
@briani_davide , I tried but didn’t succeed in get the BIOS file. So I have to open the tablet to check connections and get more information to try some fix.
Here’s what I found:
Texas Instruments ic BQ715 Battery Charger Controller
ITE ic IT5570E Embedded Controller https://www.ite.com.tw/uploads/product_download/IT81202_B_V0.3.2_20201030.pdf
According to system76/ec - githubmemory
Datasheets for the ITE embedded controllers used in System76 laptops cannot be shared outside of company. (However, the IT81202E datasheet is publicly available. While it uses a different core, a significant portion of the register information is the same as IT85878E/IT5570E)
¡BEWARE! ¡NEWER MODELS DON’T HAVE PEN SUPPORT! I bought my tablet for drawing, and now I am stuck with a device that does not support the pen.
More people are having the same problem, and the only reply from Chuwi support is “your model does not support the pen”. They must have supply problems, or whatever.
