Chuwi hi10 max Linux Fedora, need drivers
I duel boot my chuwi hi10 max with Fedora 40 ,it just work awesome. Where Wayland touch support is very good but only Firefox browser copy paste feature work correctly not other browser, I also use xorg when I use mouse.
Here is the video to help keep remember you need to bios disable secure boot and fast boot . I didn’t found any driver issue, Bluetooth, wifi speaker. Maybe there is some issue with camera I didn’t tried to be honest.
We cannot offer support with Linux , as we dont provide it. Maybe other users can help you
We apologize
Nice example how well Fedora works on this device. I installed Fedora 41 KDE mobile beta on my minibook x. At login it allows you to select Plasma desktop or Plasma mobile. It’s a different experience from Fedora workstation that you have installed.
BTW, I did not disable secure boot.
Jaap
I can confirm that it is not necessary
I can imagine that you disable secure boot in a windows dual boot environment. It’s not obvious to get in UEFI settings when that’s enabled.
This is how you can get access to BIOS settings after Windows 11 has started.
Start PC
Log in
Press the Windows key
Select Settings
Select Windows Update
Select Advanced options
Select Recovery
Select Advanced startup, Restart now
PC resets
Select Troubleshoot
Select UEFI Firmware Settings
PC resets
You can change BIOS settings
Cheers, Jaap
