I have a official version Chuwi Hi10 Plus Dual Os 4G/64G tablet that turned off while using Windows 10, started charging all night until the led remained solid, the charger was disconnected and the led began to flash again and did not start. After leaving the power button pressed for about 2 minutes, the LED went off but the tablet has not started again, I have checked all key combinations that I have been able to consult in forums on this model to start it in some way but none have had effect.
I have verified that the charger is in good condition and that the battery has a charge and offers the correct voltage, also that when pressing the power button to try to start it, there is a sound below the buttons as if trying to pass current but never comes to start and with the keyboard connected the LEDs blink every so often.
It is a topic reported on other occasions and with multiple causes that will have to be ruled out one by one.
You have already done a good review removing some of the possibilities like battery and charger.
Sometimes the keyboard itself is the one that has prevented the tablet from turning on, turning it on when disconnecting it from the dock.
The next checks are the power button and the Bios.
The first is hardware and to check it you would have to open the tablet and put the poles of the switch together.
The second is to reprogram the Bios using an external programmer. There is a tutorial in the forum and you will need some accessories.
Thanks for early answer, about reprogramming the BIOS I am not very sure because it was working without problem and Windows had not been updated, and about put the poles of the switch together I understand that it would be if I did nothing and if I connect it to the keyboard to press the power their leds shine.
Admittedly, the tablet doesnât turn on at all, the screen doesnât even turn black, but itâs getting voltage and hasnât been updated to have to reprogram the BIOS, unless pressing the power button for almost 2 minutes has reset the BIOS, Could this have happened?
The important thing is that it turns on, it does not matter if it enters recovery mode since, if it manages to turn it on, we can repair it with an external pendrive
Unplug it from the keyboard and never shut it down while plugged into the keyboard again! This has been a known issue since these things came out.
I thought I bricked mine when it happened to me! Just always remember to take it off the keyboard when you shut it down until the LED begins fast blinking again while plugged into the charger and then you can reconnect it to the keyboard. Just remember to always remove it before powering down.
To get it restarted now, get it off the keyboard and charge it for a while -hours to overnight until you get a solid power LED, then try the 20 second long press on the power switch, with it off the keyboard base, and then immediately try 3 presses at about 1/2 second interval and see what happens. Try it plugged into power and unplugged both.
As far as I know, this is a situation that has been around with these units when connected to the physical keyboard dock since the very beginning. I think I had it happen twice way back when I bought it around 2015 and didnât know it was an issue, and then forgot another time. What seems to happen is that it looks like it shut down, but somehow powers back up and runs the battery down to nothing while connected to the dock. As I recall I had to plug mine in and let it charge a couple hours until I hit on the correct power button reset combo. The 20 second long press apparently guarantees itâs fully shut off. I guess the three clicks get it going again,. No idea why it takes three rather than just a single press, unless that is an internal reset for the electronic switch/battery management chip used in these devices. All I can think of, really.
Let us know if this works for you, but get it off the dock to get it turned back on and donât EVER shut it off while connected to the keyboard dock in future. You can reconnect it to the dock once the LED has started fast flashing to Indicate it has shut down completely and is now fast charging if you leave it plugged in. Otherwise, give it at least thirty seconds after the screen goes off before reconnecting to the keyboard/dock and folding it closed. I think it only happens if you shut it down while connected, but canât recall if it was an issue if you just closed the tablet on the keyboard to get it to go into sleep mode. Once you figure out how to reset it again from what Iâve written you can try it if you like, I just avoid it completely!
BEST OF LUCK! Please let us know if this gets it going for you. It has worked both times it happened to me.
Thanks for the answer, but what you comment I have already read in other forums and open topics and I have already verified it, the question is that the LED does not light even with the charger connected. When trying to turn on the tablet, the only LEDs that flash intermittently are those of the keyboard if it is connected, and there is also a flashing sound as if trying to get power, but nothing else.
If pressing the power button for 2 minutes could have reset the BIOS and this is the problem, I would like to know what would be the download link for the Chuwi Hi10 Plus CWI527 LQ64G421803XXXXX BIOS.
La soluciĂłn puede pasar por desconectar la baterĂa durante unos 15 minutos y volverla a conectar. La Bios volverĂĄ a los valores iniciales.
En caso de tener los medios para reprogramarla, debes solicitar los ficheros a service@chuwi.com
Pues mi gozo en un pozo.
Tras soldar la baterĂa he notado que en la zona del microprocesador subĂa la temperatura, o sea que algo estĂĄ haciendo, pero no enciende.
He probado lo de los 30 segundos, 3 pulsaciones y nada, pantalla apagada.
La bateria se va drenando, sobre todo si la dejas con el teclado conectado.
Si la baterĂa llega a activar la protecciĂłn para no descargarse totalmente, debes poner el cargador y esperar varios dĂas, puede que mas de una semana, y poco a poco ira cargĂĄndose y encenderĂĄ normalmente
