Where can i buy a replacement charger for my Chuwi Hi10 XR
It’s a non-standard USB-C charger, so I doubt you’ll find anything that outputs 12v dc directly into a USB-C plug. I needed a car charger for mine, so bought a 12v 3a power supply, and cut off the cable and attached a USB-C plug to it. You could to the same with any 12v (2 or 3a) power supply, and simply make your own.
Thank for the info and I will probably do the same as you.
You would think Chuwi would make replacements available to buy.
All the best Ian
